And, how do you find that processor of yours working for you? Does it crash regularly (or, not)? If so, with which Topaz products does it work well/badly?
Do you find it slow to process your images (what do you consider slow)? Does it seem to work more slowly with some Topaz products than others? Which ones?
Oh, and if you respond, perhaps would be good to mention make/model and OS you’re using the processor with…
OK - first a disclaimer. I had my PC rebuilt two weeks ago so cannot talk with any real confidence yet about current performance levels.
When Studio was launched I had 16 GB RAM and 1GB onboard graphics. I had terrible trouble just browsing Studio particularly when in Impression and (I think) Glow to the extent that Studio would crash. So I added a 2GB graphics card and everything ran fine.
Then AI Gigapixel came out and upped the requirements. No real problem until Sharpen AI at which point it was just painfully slow. So I upgraded to a 6GB graphics card (trying to get one step ahead this time!!). No problems after that until quite recently when at random times my PC would reboot - but always when running Topaz apps. Suspecting it was more likely to be a problem with my ageing PC (it was rebuilt five years ago) than with Topaz I decided it was time to renew it, hence the recent rebuild.
Current specs (note new version which appears to have launched since I started writing this):
Application & Version: Topaz Studio 2 Version 2.0.11
Graphics Hardware: GeForce GTX 1060 6GB/PCIe/SSE2
OpenGL Driver: 3.3.0 NVIDIA 431.70
CPU RAM: 32701 MB
Video RAM: 6144 MB Total, 5579 MB In Use
Preview Limit: 7856 Pixels
No problems at all using any Topaz app over the last two weeks and everything runs quickly.
I’ve been running a GTX 1050 with 2GB video RAM for more than a year with no problems on any Topaz software. However, I was having general problems of running out of CPU memory and would sometimes have to close one thing to open another. But those issues are gone now that I’ve upgraded from 8GB to 32GB CPU memory.
That’s a big jump. It’s helping to hear how other users Adjust (see what I did there…) to improve performance and how the tail seems to be wagging the processor/computing power dog - as it were.
All Topaz apps seem to have adequate HW resources since I updated to these specs May-19 and processing wait times are very reasonable. In general, the more VRAM the better.
No trouble here using any of the Topaz products. I have each of them set up to run using High memory consumption on the GPU, and to run in the Foreground. The GTX 980 may be a couple of generations old now, but it was top of the line in it’s day, and still outperforms much of the lower-middle end of the current cards.
My factory Super-Clocked card is modestly overclocked (100 Mhz) using EVGA’s Precision XOC.
I also use Wagnard’s Intelligent Standby List Cleaner to automatically trim my Win 10 Standby Memory whenever the system Free Memory drops below 1024 MB.
The monitor is ASUS’s ROG Swift PG348, 100 Mhz Gsync, 34" Curved Widescreen @ 3440 x 1440.
The CPU is an i7 7700K Unlocked running at 4.6 Ghz.
The GPU only score is about 25%. And while the combo CPU/GPU is higher that is based on what the Neat application uses (or can use). Topaz prefs have the binary (CPU or GPU) setting so it’s not clear if the combo score is relevant. You might have to consult with TL support more in depth. But, this could be a source of any non-optimal performance. Fortunately, it’s a relatively easy fix…it will just cost $100-$200 [for a more robust GPU].
My old Intel i7 had a HDD system drive, 16 gig ram and no GPU.
My new build is a AMD Ryzen 7 3700 8 core, 32 gig ram, SSD system drive, ASRock Extreme 4 MB and AMD Sapphire Radeon 5700 (8gig ram).
The new system has no trouble keeping up with any of the AI products. You really have to throw some hardware at it. BTW, I’m not a gamer (unless you call post processing gaming) so I don’t need a high end GPU.
The way I do it I think it is sometimes “gaming” the system of “straight” photography… But I’m with you wrt practices (and typical gaming is not one of them…).
I have a Ryzen 5 2600X CPU system with 32GB of DDR4 3000 MHz RAM and a Gigabyte Radeon RX580 video card with 4GB of memory. It runs all of the Topaz software well and is fast on photo programs and Corel Painter 2020. The OS is Windows 10 (v1903). I ran the Neat benchmark below.
You will have to install new drivers but it should run with the driver that Windows installs, then you can download and install the latest driver from the Mfg. website.
