Where is resume from download Topaz Video
Can you elaborate on the situation you are looking for?
If the file has been sent to the cloud and has finished processing, you can download it from the Cloud Export Queue. There is an option to redownload a file using the three dots to the right of the file, however, that will only work within the first 7 days since the file was run. After that files are cleared from the server.
If you have paused and export when running locally, in the export queue you can click to resume a process using those three dots as well, but this is not an option if using the Starlight models, or stabilization.
