When I use "Edit in" in Lightroom it opens De Noise AI but before it used to open the Lightroom Picture straight into De
Steps to reproduce issue:
  1. Step 1Go to Edit in Lightroom and choose DeNoise AI
  2. Step 2 It then opens a box and asks you to drag the picture into it.
  3. Step 3 Before it would open the picture straight in to De Noise in the previous version
No I can only export the photo from Lightroom to the desktop and then drag it into the box.
Can this be sorted out?
Thanks Chris
Please raise a support request at the main website.
When you choose Edit in it should present a dialog where you can select the file type and whether or not to include LR edits in the output file to send to DeNoise AI.
