When I output it in prores, only audio appears and no image appears
Topaz Video AI 5
When exporting, the image quality seems to be slightly better with h265 than with h264.
I thought it would be better if I output it in prores, so I output it, but no image appears.
I often use mp4 as the original file.
The types of videos are mostly recordings of TV (CS broadcasting FHD), YouTube, and commercially available DVDs.
My PC is a Windows 11 RTX4090 that I bought a month ago.
The settings I often use are
No presets
Output is 2x
Enhancement starts with progressive and then various others.
Other than that, I only use motion deblur.
In this way, I can output h264 and 265, but when I output it in prores, only audio appears and no image appears.
I tried four different profiles but the results were the same.
I did not touch any other settings.
Are you able to upload and share the logs from the app?
