What is the best way to deinterlace and upscale films from DVDs using the Dione and Proteus models
:+1: Same feeling here…
CRF at 0 is lossless… Encode/H.264 – FFmpeg
However I don’t know if VEAI respetec the correct parameters for a true H264 lossless encoding… :thinking:
I have to do extensive comparations between H264 and FFV1 to see if there are significant differences in quality between the two. @Akila mentioned before in this same topic that he can’t spot any difference between the two.
One think I’ve checked in the short tests I’ve done is that FFV1 encoding speed is faster than H264… 4minutes for a 42minutes source. If one are processing long sources only that difference in encoding speed is to be taken in account.
like I mentioned before, i got zero knowledge when it comes to Telecine, so I have no idea if it does, I only work with interlaced videos that were shot in it’s original fps as it was stored.
if you mean FFV1, I am talking about Hybrid. you can see my screen shot earlier in my post in this thread. FFV1 is basically ffmpeg forking of h264 to my understanding, so i am not expecting any quality difference to be honest, but performance might be different, i think it’s a bit quicker then h264.
Yes I’m talking about hybrid, I’m still testing the H264 at the moment. But you say that it is lossless and that the files are therefore large, but they are 95 MB/s in AVI H264, so it’s not so big I find :slight_smile:
For TVAI’s FFMPEG, x264 or x265 cannot be used, so h264 such as nvenc or qsv must be used.
I looked up the options for h264_nvenc.
As for lossless, it seems to be specified in preset or tune (I haven’t tried it).
"C:\Program Files\Topaz Labs LLC\Topaz Video AI\ffmpeg.exe" -h encoder=h264_nvenc
Encoder h264_nvenc [NVIDIA NVENC H.264 encoder]:
    General capabilities: dr1 delay hardware
    Threading capabilities: none
    Supported hardware devices: cuda cuda d3d11va d3d11va
    Supported pixel formats: yuv420p nv12 p010le yuv444p p016le yuv444p16le bgr0 bgra rgb0 rgba x2rgb10le x2bgr10le gbrp gbrp16le cuda d3d11
h264_nvenc AVOptions:
  -preset            <int>        E..V....... Set the encoding preset (from 0 to 18) (default p4)
     lossless        10           E..V.......
     losslesshp      11           E..V.......
  -tune              <int>        E..V....... Set the encoding tuning info (from 1 to 4) (default hq)
     lossless        4            E..V....... Lossless
But the problem is that h264_nvenc is limited to 8-bit output.
TVAI 2.x.x has 8bit internal processing so there is little loss, but TVAI 3.x.x has 16bit internal processing so it would be a waste to output at 8bit.
I need to test NVENC to see if there is any speed gains and if at least NVENC lossless quality is on par with Cpu encoding.
Since I’m processing 8bit sources I don’t know if I gain anything in outputting to 16bit…it doesn’t hurt to try anyway.
Thanks for your info :+1:
Thanks! Thought I’d share that ChatGPT is a good sidekick for all these procedures.
https://chat.openai.com/share/c60b9c3c-a669-44ae-901a-3ebe92c3f8b2
I’m not a pro, sometime i try to work on dvd 720x480 bff, I use first dione DV and second pass od artemis low..look good
Or also second pass of dione robust..
After months I try to change setting…almost dont know how its the best :face_with_spiral_eyes:
