The presets were great for one tap sports design. The new Adjust AI doesn’t seem to have these presets.
Yes, you’re right. You won’t see the former presets (at least not with the same naming).
Do you still have the “classic” Adjust installed, if you have favorite presets you used in it? I regularly use some of the older programs for the features I liked in them…
Try to get your head around an idea that the Topaz Studio(s) software is really an expansion (on acid) of the original Topaz Adjust. New TA does not have a patch on old TA - at least in terms of presets - but once you understand what each slider does, it will not be long (with a little experimentation) before you begin to emulate old TA.
