Weird square artifacts after raw denoise
after raw denoise. theres a grid square-like pattern that overlays on top of the photo. only occurs in topaz photo ai. if I use just the denoise ai program it doesn’t do this.
  1. The original image file.
  2. The processed image.
Dropbox File Request
