It still seems strange using a workflow that goes from DeNoise to Studio 2 with a TIF, as RAW conversions are not exactly the best, apply a curve and create a watercolor effect, then off to Studio 1 to add a Digital Frame mat only and add an image layer …
…but you can add a digital frame/matt only in TS2
Sure Jack but I needed the overlay placed at the same time anyway
I like the V2 interface, process better but I wish they would give the same functionality as 1 …
Me too
