vRAM usage always at 100% with Starlight Mini
I’m trying to use Starlight Mini on my system with an RTX 3080 10GB, but the memory usage is always maxed out at 10/10GB, no matter what I set in the settings. I’ve tried restarting the program, rebooting my PC, and even reinstalling the software, but nothing helps. I’ve tested every percentage from 10% to 90%, and it always uses 9.7/10GB of VRAM plus 2GB of shared memory. I’m only getting 0.1 FPS, and I know I could double that with lower memory usage. Is there any fix for this? Thanks.
The team is actively working on issues with Starlight Mini that are causing some users to experience this issue.
We are hoping for a patch release to be ready to share as soon as we get it through more testing and confirm the problem is resolved.
Option for disabling shared memory use would be helpfull. Problem is some shared memory can also happen when VRam is not maxed out
