VOBfile (DVDfile)
    I output the VOBfile (DVDfile) with 4x scale, interlaced, AutoDetect, Dione dv 2x fps settings, but it always stops with an “Unknown error” message.
  2. Your system profile
    Windows11
    RTX3070
    intel core i7 12700K
    mem 64GB
DxDiag.txt (169.4 KB)
  1. Any screenshots as necessary
Hello,
Let’s take a look at your full log files to see what could be causing this error
To gather logs, please select Help > File Logging and make sure that there is a check mark next to File Logging. Next, recreate the issue and then return to the Help menu and select > Get Logs for Support and attach the zip file to your reply.
Thanks!
I am very sorry, I have updated the Ndivia driver to the latest version and it solved the problem. Thank you very much for your time.
Glad to hear it’s working now :slight_smile: Feel free to contact support for any other questions you have.
