Hi, When I try to upscale a video, it won’t utilize my GPU and when I force it to, it crashes
GPU is an NVIDIA GTX 1060 3GB
That’s a slow slow GPU there Noah. Shut down all browsers, updaters, windows indexing - in fact anything that is using up resources - before you try and use Gigapixel video.
It is the ultimate and most resource-hungry of all Topaz Labs AI apps.
The minimum VRAM requirement for Video Enhance AI is 4GB - so you might need to think about upgrading your graphics card.
I have a 1050TI with 4GB somewhere, can that be used?
You will have to try, but it is closer to the spec that Topazlabs recommends
