Video is converted from 59.47 fps to 7.58 fps problem is still present with TVAI 5.3.1
This is a bug I previously posted about in May that is still present.
The old topic closed after 60 days of inactivity
That is why I am posting this again.
When applying Proteus the fps of the video drops from 59.47 fps to 7.58 fps
System Profile is
Model Name: iMac
Model Identifier: iMac19,1
Processor Name: 6-Core Intel Core i5
Processor Speed: 3.7 GHz
Number of Processors: 1
Total Number of Cores: 6
L2 Cache (per Core): 256 KB
L3 Cache: 9 MB
Memory: 80 GB
Radeon Pro 580X 8 GB
Big Sur 11.7.10
  2. Your system profile
2024-09-01-14-48-32-Main.tzlog (63.5 KB)
Are you able to share the original input clip along with the exported one out of Video AI to my dropbox for testing?
You can securely submit your file(s) to our Dropbox using the link below. Please be sure to send me a note to let me know you sent something.
Submit File to Dropbox
Hello
I just uploaded two files named
Kiki and Mark Wedding new capture svideo_prob4. Has decreased frame rate
Original File
Kiki and Mark Wedding new capture svideo.
Thanks for sending the file. I ran some tests and looked at the logs from the last forum post you made and the app was reading the tbr (time base real) frame rate at 7.58. I rewrapped the original file using handbrake and brought it back into Video AI and was able to get it to export correctly in 59.47fps.
Let me know if re encoding it works for you!
I turned it into a .mkv file and that seems to have done the trick. Now when I render it the render plays at the proper frame rate.
