Video Enhance AI v.1.2.3 - Gaia-HQ model improvement (hotfix)
Pretty sure thats wrong
But while I’m here a pause button would be great its frame at a time anyways right?
Any chance on getting a native linux version?
You’re using Qt, Tensorflow, ffmpeg, … all stuff that is just made for cross-platform support.
Video Enhance AI already works pretty well on Wine, btw, but without GPU support :frowning:
When is the online version getting put back up? It’s been “down for maintenance” for weeks now! My computer is too weak to use this software.
I appreciate the offer, but I have about 17 hours of footage to process, I don’t want to bother you.
Dear All,
FYI, I tested the performance of Titan X (Maxwell) and GTX980.
With same video, I tested Gaia-HQ 2x (720 → 1440) in v.1.2.3.
Result
GTX 980 : Used the memory about 3.6 GB, 0.82sec/frame
Titan X : Used the memory about 9.4GB, 0.42sec/frame
There is almost 200% performance difference.
here, are the results i have with HD 630 Graphics intel lol (your result make me jealous lol)
All these are converted to full HD : with i7-7700 + 32gb Ram
1280720 => FHD : 6.34s/frame
960x540 => FHD : 3.57s/frame
854x480 => FHD : 2.86/frame
720
400 => FHD : 2.82s/frame
640x360 => FHD : 2.32/frame
554x416 =>FHD : 2,13s/frame
(i was doing a vegas rendering Cpu 100% + igpu) while using VEAI
480x240 => FHD 1,29s/frame
448x336 => FHD : 1.06s/frame
Anyone with recommendations with a proven PC configuration that works fairly well with GPU in the $1,000 or less range? That would be for a PC dedicated to that task only and no other needs.
Really? Hehe, Got to try that.
??? really ? i didn’t even noticed we could change the cropping lol ! i will try immediatly ! lol !
Hum Test 1 Gaia CG
640x480 = Crop so no black bars. = 1850x1080 300% = 2.29s/frame
same video with 1920x1080 = 300% black bars left and side (not a lot) = 2.86s/frame
very interesting. i’ll have to do a second test, to be sure it’s not related to have a widht more tiny , and that’s related to the black bars ! thanks Atari.st ;)… unfortunatly it’s produce none acceptable ratio, but we can recompress it using an another encoder ! Nice One !!
696 x 480 = 313% 1920 x 1080 (removed black bars) = 2.12s/frame
696 x 480 = 275% 1920 x 1080 (black bars up down left and right) = 2.70s/frame !
Ahahahah ! Nice one ! Congrats to Atari.st to have found this !!
I am not talking about VBR but VFR - variable frame rates: Variable frame rate - Wikipedia
:slight_smile:
Because lossless is lossless and -c:v h264_nvenc -preset lossless is faster than -c:v libx264 -crf 0 on my system (AMD 3900x & RTX 2060 KO)
Did the last update make any changes to the GAIA CG mode because it looks different? The “cartoon effect” has increased
I disappointed this result because there is a bit difference between RTX Super 2070 and Titan X (Maxwell). (Truly, the gap of performance between two cards are significant).
When you use it in low quality video, faces looks like smeared with watercolors :unamused:
May you fix this?
I stand corrected, I didn’t realize you could do lossless with nvenc
I am using an RTX 2060 and get anywhere between .38 and .45s/frame for 720x480 29.97fps upscaling to 4k, and .85s/frame doing the same resolution but 59.94 fps. Not fast by any stretch of the imagination, but decent. The RTX 2060 is listed as having the same CUDA compute power as the 2080 so I have no idea if that card would yield significantly faster results or not.
I upgraded to 1.2.3 and now no video can be enhanced on my computer, never had any issues before.
Running latest RTX 2080 driver (studio driver) and all that happens with any video i throw at it is that it loops the first 30 frames of the video and then just repeats, this is what is being shown in the preview window.
It does not matter if i set the program to use CPU or GPU it simply just loops the first 30 frames and nothing.
I never had any issues with 1.2.2, any ideas?
Are you sure you are pressing the Process button and NOT the Preview button?
Preview is at top right, Process is at bottom left.
