Video Enhance AI thoughts and requests
Have you checked fps before and after you render with VEAI?
I just ran this test with a short clip. The source was 24 fps and after encoding it with VEAI the frame rate is 29.97. I’m using 1.1.0.
EDIT: I may have found the issue. MediaInfo is telling me the source file is 24 fps (which makes sense since this is a DVD rip of a TV show) and VEAI is detecting it as 29.97 when I load it. So maybe VEAI is just reading the fps incorrectly?
Oh wow, maybe that is the problem. I can’t test right now because it is currently processing a file, and still has a few hours left. But I’d be interested to see if VEAI reads the files that it produces incorrectly. Even then, mediainfo is still telling that the final file is correct fps. Will update once I test.
Sounds like your source might have some kind of Telecine or 3:2 pulldown going on.
How to check this: https://tommycatkins.com/2020/Neuron2_Video_Frame_Structure.htm
If you have such source material, it should be deinterlaced first, then decimated (remove the duplicate frames inserted for interlacing, restoring the original 24 fps).
Try these Hybrid settings if your source is 30fps telecined and you want to get it to 24 fps:
Further testing at home with DVD:
Gaia HQ seems to do the least. Looks like a regular scale with a little detail enhancement. Tool tip says this is really intended for HD sources. (So I’m guessing 1080p to 4K basically.)
Gaia HQ-CG is a mode a lot of people seem to like. I have found that currently, in some sitations, it adds “pattern dither” types of artifacts that are clearly visible even when viewing at a distance on a TV screen. It looks similar to say dithering an image to a 64 or 32 color gif with pattern dithering. I think it’s coming from the training data trying to re-create detail. This effect doesn’t appear in other modes.
The “Artemis” mode is greatly improved. THESE are the settings to use for scaling standard video (480p) to HD (1080p).
Artemis-HQ looks good but sometimes leaves details more blurred than Artemis-MQ. It can also “enhance” certain slightly noisy elements. I think it really needs to be used on only VERY clean sources.
Artemis-MQ seems to be the main setting to use for upscaling DVD and other average to good quality HD sources. It produces the most sharpness in fine details while denoising and removing some other slight artifacts. The file size is only slightly smaller than Artemis-HQ which to me says some denoising is taking place. Film grain is still mostly visible.
Artemis-LQ when used on the same sources begins to start resembling Gaia HQ. Detail is once again lost and many scenes take on a “painter” type of effect. This I believe is due to heavier denoising and deblocking. This mode is inteded for low bitrate sources with visible blocks and artifiacts so it’s mainly trying to remove those. Don’t expect it to save very poor quality VHS or 1990’s “postage stamp” sized video encodes from RealPlayer.
On several discs, including good quality 1970’s films with visible film grain (which you want to keep), and recent 2000’s movies with no visible grain, Artemis-MQ seems to be what wins every time.
Hi there
If I understand correctly Ai works by using a lot of processing power from huge servers and the more times it runs stuff the more it “learns” thus improving the program.
Wouldn’t it be great that they make an app or something like the one the used with the SETI stuff so we could contribute with the unused portion of our own cpu/gpu to improve it?
I’m not sure if this is the right place for this or not, but I have a few requests for usability. Simple little things that probably wouldn’t take much to implement.
  1. if a project is running and it’s closed, I’d love to have a message pop up and warn me… maybe even prevent closing altogether if a job is running.
  2. Provide a que system where the state can be saved. If I add a few jobs to be processed and I close the program, when it’s restarted have give me the option to load the previous jobs… even if it’s just saved in some sort of project file.
  3. <deleted - in version 1.2>
  4. <deleted - in version 1.2>
  5. Please allow custom preview times. Sometimes I’d like to just see a little bit longer preview!
If this was a free app I would agree, but it’s a paid one and not on the cheap side. I would like to discourage devs on asking users’ horsepower for DL unless we somehow get paid for it. Also depends on how they got they ‘neural network/deep learning training’ done. I hardly believe they do their own training, most likely they rent the power from another company. If I am correct, NVIDIA rents their own GAN database to others. They use huge amounts of their server GPUs (like de DGX-2) to create that, feeding millions of images per day, so I’m not sure a user outside of NVIDIA’s network could feed anything into it, unless NVIDIA themselves makes something along the lines of SETI@H and F@H.
To be clear here, I’m not a dev, but I am certain that this program works 100% locally. It does not rely on any online sources for its work. That’s why it’s so slow.
Well its just that I’m amazed by how much the program has improved from the first version I tried to the current version (1.2).
I was just converting a dvd pal movie to 1080P and 1.2 did manage to work like at 2x or more speed and with better quality (artemisHQ seems to works best than older CG for that)
I just hope it keeps getting better and better and I think we can all agree that if we can help to achieve that faster, well…
Trying to get Aliens in 4k from the BRay (GaiaHQ) and getting 1.9 frames/s with my 1080Ti…still way too slow! I think it will probably take all day to do 50 minutes.
If you were refering to my comment, I never said the app works online, as I’m pretty sure everyone knows that it works with your own GPU. @gargamel9 was refering to DL training so I commented on that. What VEAI does is DL-based image enhancing. DL training is another thing, VEAI doesn’t do DL training and is a MUCH more demanding task, our PCs would do only around a hundred images per day working 24/7 (using FP32 instead of INT8/FP16 which actually would be prefered, but comparing FP32 because VEAI uses FP32), compared to thousands enhance per day you can do (taking on my RTX2070, of course each GPU will do different) with VEAI.
I actually had to roll back to 1.1 because 1.2 was getting errors and taking much more time to encode than 1.1
I have been using Video Enhance AI extensively for weeks now; still in the trial version that let me extend it.
Version 1.2.0 has now been released and can be downloaded.
Since the last updates, audio has also been processed and when using GTX / RTX you can clearly see performance improvements.
Fortunately, faces and structures have only been “destroyed” in rare cases since the last versions.
Only with the CG mode can I achieve significant improvements with old VHS / SVHS / Hi8 material. And they are usually very, very impressive. If you consider that the source material is really very “dirty” (picture noise at the highest level, block formation over the whole picture, frayed / indistinct edges, blurring anyway), it almost borders on magic, which video enhancement AI does in part. In the past I had ‘learned’ garbage in / garbage out 'and only made such a video worse. I have now a very different and very positive experiences in the past few weeks.
HOWEVER: the weakness of the tool in CG mode lies in the addition of new artifacts / structures. It doesn’t happen with every clip. Most of the time the net-like / point-like artifacts are used in landscape shots e.g. Plants, trees and grass added; sometimes stronger / larger and sometimes less pronounced. Apparently AI is still learning how to deal with plants, grasses, etc. I don’t know if that will ever be possible.
But I have long since found a workflow to get this under control to some extent. AND, the results are sometimes incredible; especially in the before / after comparison:
1.Deinterlace AVI material with Tmpgenc Masterworks 6 or 7 with deinterlace in HIGH PRECISION mode and render with 1280x720, 25FPS, 30Mbit in MP4
2. Denoise the new MP4 with Neat Video … but only very “tender” … until the noise in the sky has almost disappeared (only almost!) (Use it in Magix Video ProX)
3. Perform color grading in the sky >>> at VHS / S-VHS / HI8 the sky was mostly purple at that time … (use the color adjustment tool in Magix Video ProX … very quick / easy for it)
4. Allow video enhancement in CG mode and render 200%
5. Color grading is best in my case = ColorDirector from Cyberlink (works similar to e.g. Luminar … therefore simple and fast and has motion tracking)
That sounds like a lot of work in advance and afterwards … true! :slight_smile: But, the results are definitely worth it. I never thought that I could get so much out of the old, bad material. Of course the end result doesn’t look like 1080p / 2K or 4K …
Disagree, with my RTX 2070, 1.2.0 is a significant retrocess and has only made things slower to the point of unusable (40minutes of 24FPS video, from 720p to 1440p, with HQ - now Gaia-HQ - would ever since 1.0 took around 24 hours to make, with 1.2 it shows more than 5 days to do, and was getting slower and slower as the encode progresses). Had to move back to 1.1.
Appreciate the info about the commercial software you use.
For your steps 1 and 2, I would encourage you to try QTGMC for both deinterlacing and denoising.
You don’t have to spend all kinds of time configuring AviSynth or anything, just install Hybrid, run it, and set the options.
I would start with these settings for QTGMC:
Turn “Final Temporal Smoothing” down from 3 to lessen noise removal. “0” should be off. You can also turn off the “Source Matching” and “Lossless” settings as these can add noise back, for example turn these off and try turning up “Final Temporal Smoothing” to 1, 2, etc. The upper button in the lower right will turn on real time preview. You can also set “Sharpness” to 0; I find .1 to .5 settings are useful. I would not mess with any of the other settings.
Any chance of getting a pause button? I game with my system and need to free up my RTX 2070 from time to time. My videos take 8+ hours to process. I thought of doing a png series and just resuming from the appropriate frame number but those png’s take too much disk space to be practical. It would be great if we could pause an mp4 file.
I initially was using the 1.1 version, and the upgrade to the 1.2 version was a significant improvement for me, particularly with respect to processing time. Mostly I am working with 480p to 1080p conversion, but my RTX 2070 has now been processing approximately one frame every 0.3 seconds.
I think people need to uninstall the prior version fully before installing the new version, and ideally the installer should do that for you when upgrading. I initially did not do that and was having some instability, but the clean install of the program seemed to fix that.
Currently, my only major request is that the output encoder needs to be either switched to a near lossless h.265 or give the option of this. Finally the option to keep the sound should use direct stream copy. This would be both faster and less likely to introduce new artifacts than reprocessing the file.
I always do that :thinking:
What’s your OS? And Version. Also GPU driver version would be nice, too.
As I’m in the middle of an work right now and I don’t want to lose 20 hours of VEAI, I’ll wait until it ends tomorrow (23pm here) before doing anything, but maybe it have something to do with OS version and/or driver version.
For me I’m on Windows 10 Pro Insider Preview (Build 19592), GeForce Game Ready Driver 450.12 (23/03/2020)
Windows 10 64 bit Build 18363
GeForce RTX 2070 Super with Driver 442.59
So plissandro, you are running both a preview OS build and a preview graphics driver build. If you have any instability I would start with that.
I keep my preview OS use to my extra devices not my core workstation.
to be fair the only instability I have is VEAI 1.2 taking WAY more time than 1.1. Any other app works flawlessly, as the Preview WIndows Builds are nothing like a beta version or unstable in any means. The ‘preview drivers’ are also pretty much the same as regular drivers (they actually update a lot less frequently then regular drivers, last one before the new was from october), but they are only for Insider Windows Versions because they use the new WDDM 2.7 (that will be implemented in the next version of windows).
There maye something meddling with VEAI performance in there, though. I will DDU-uninnstall my drivers and revo uninstall VEAI 1.1 than reinstall drivers and VEAI 1.2 and see if it keeps the horrible performance.
Also, are your videos long? Because With 1.2 I started with about 1 frame per second, then performance would go down the road until it was unbearable at 30 seconds/frame
My videos are up to at least 1.5 hours. The performance holds steady at .3 seconds per frame unless I am simultaneously encoding other things in which it drops to .5 seconds per frame but immediately returns to .3 seconds after the other process completes.
I have a long history of using windows preview builds on my non core computer, and there are regularly inconsistencies with other software as they make small alterations.
