Video conversion process may terminate unexpectedly in v3.5.1
  2. Your system profile
  1. Video conversion process may terminate unexpectedly in v3.5.1. The ending point is not fixed. There are some videos that can be converted successfully.
    Currently, I uninstalled v3.5.1 and installed v3.5.0, and it is working without any problems.
  2. 12th Gen Intel(R) Core™ i7-12700 2.10 GHz
    64.0 GB RAM
    Windows 11 Pro 22H2
    GPU: NVIDIA GeForce RTX 3070 with 8GB Memory
3.sorry. I completely uninstalled it, so there are no logs left.
My Preset is:
“Terminated” is not accurate. It is accurate to say that the procedure is interrupted and does not proceed further. Also, there is no reproducibility at the interrupted position.
Hello,
Could you send us a note at help@topazlabs.com with the full log files from the app?
To gather logs, please select Help > Logging and make sure that there is a check mark next to File Logging. Next, recreate the issue and then return to the Help menu and select > Get Logs for Support and attach the “logsForSupport” file to your reply.
sorry. I completely uninstalled v3.5.1, so there are no logs left.
I’ll try again when v3.5.2 comes out.
Until then, I will use v3.5.0
