Video AI 'Keep original frame numbers' option does not do anything
  • Using the ‘Keep original frame numbers’ option when exporting frames will always start at 0.
  1. Your system profile
  • Win11, RTX4080 Super, Ryzen 5800X
  1. Your log files (Help > Logging > Get Logs for Support)
    logsForSupport.zip (9.7 MB)
  2. Any screenshots as necessary
Can you reach out to help@topazlabs.com?
Please share the original and the exported file with the frame rate issue to my dropbox
Submit File to Dropbox
I shouldve been clearer.
The exports are image sets, so input is any video, output is to image set.
Doesnt matter if you have any enhancements. Could be none.
Str:
  1. Select start position that is not frame 0
  2. In output codecs tab, select image set
  3. Check the box “use original frame numbers”
  4. Have it export to folder
  5. Export
If you check the resultant images, the numbering will start from 0
Thanks for clarifying, I just put in a bug report to fix this.
Thank you!
This feature is important to me as i cut, crop, upscale parts of videos and store the results all in the same folder.
Right now i have to manually rename the frame numbers using power rename on windows
Hello, is there any update on this bug?
