The bug / behavior you have encountered
After processing two or three videos successfuly Video AI crashes. Sometimes it destroys the task it was working on, sometimes it is completed. When I restart Video AI it is in Trial Mode and I have to Activate it again.
Your system profile
AMD Am4 system:
CPU: 5950x; RAM:Crucial ballistix 2 x 32G 3600;
MBD:ASUS X570 Strix-E Wifi II
GPU: NVIDIA A5000
Thanks for looking at this.
I’m uploading a zipped copy of the Log Folder and have included a set of event errors from the Windows event viewer which might explain the activation issue.
The system is running at default values apart from the XMP for the Crucial ram.
Ok, I’ve gone into Task Manager and selected End Task on it. There’s a lot of Asus services there as part of AI Suite 3. I’m wondering If that is incompatible with Video AI, now, although I have been running these together without any problems for the last two years.
The bug has settled down now to be managable as long as I respond to the end of each task quickly enough. However, it has taken to inserting a ‘_1’ into the filename of completed exports - as if it has restarted the task at some point without saving the first attempt.
