I found a thread last week talking about a dedicated VHS model but can’t find it this week within a search?
I know a lot of people use Topaz for upscaling DVDs but I really wish there was a VHS model as I have a lot of projects where I am needing to upscale VHS footage. Results have been reasonable but not with faces from a distance being especially problematic.
I have been impressed with what Topaz does for the last couple of years using it with digital footage and mini DV, but I long for a true VHS model tha gives better results.
I deinterlace the source file first (with a 3rd party application that I know does an excellent job).
Then I feed VEAI the 480p file - square pixels of course.
I test Proteus low, med and high quality to see which one gives the least artificial results.
Then I add grain depending on how too smooth the video looks like in the preview.
Output is at a high bitrate or ProRes.
Finally, I run the resulting file through a 3rd party application in case it needs to be sharpened or not. I have 3 predefined sharpening levels to pick.
Then the same application will output the file or files into a QuickTime container with the appropriate codec I need, depending on the project.
