I had a bit of spare time to test 6.04 a bit and the VFR bug is apparently still alive ?
Can’t provide a log or sample, because I didn’t realise this error on time before deleting all the source footage.
What I can remember:
Source was a prores_ks at 2160p and 29.97fps
with Frame Interpolation (25 → 29.97) → heavy VFR on all tested models and tested codec h264,h265 + ProRes HQ
without Frame Interpolation (orig fps)
Constant Framerate for all models and following codecs: h264, h265 → slightly VFR for all tested models when output is ProRes
The ProRes VFR thing when doing no frame-interpolation into TVAI, it could be this comes from TVAI drops last/first frame(s)
When doing Frame Interpolation, it’s worser, here must be more than droping one frame and this also happens for h264 + h265
What I can say for sure now TVAI V6… do not use frame interpolation function, it gives you VFR
I did no check yet TVAI sets “CFR force flag” if there are or not double/inverted frames.
