I’m running an RTX 5090 but H.265 (HEVC) NVIDIA is not showing up on my list to select. how do i enable tensorRT?
i’m encountering very slow export speeds for minimal upscaling
What do you mean you don’t see NVIDIA under HEVC? If you’re talking about the Export settings, try changing the Profile to something like Main. Once you switch to a compatible profile, the Video Encoding GPU option should appear. Here’s a screenshot:
Also, you mentioned slow upscaling — that’s unrelated to the HEVC encoder. Make sure your GPU is selected under AI Processor / GPU Settings, because that controls the hardware used for the actual upscaling models. The HEVC codec you’re referring to is only used for the final export, after the project finishes processing.
Can you share a screenshot of what you are seeing for reference?
The processing speeds could vary depending on your system hardware, the model and settings being used, the source file and the output settings.
Would need more information to see if the speeds you are seeing are within the scope of expectations.
