Vers. 2.4
on a mac pro m1
  • sharpen doesnt work
  • i dont like the ui, it is cluttered, you need more keystrokes, and the info is more keystrokes away
  • lightning and color are just useless with one parameter to change, two for each would be much better
Thanks for the feedback. I’ll be sure to share these thoughts with the developers.
In the meantime can you provide me with some more information about the issue you are having with the Sharpening feature? Is the application not responding while applying the feature?
if sharpen does not work please check if you set the selection to “all” instead of “subject only”.
