Hello
Problems with “thm2” (Themis) that were not existing with “thm1”:
1- The wood (like a wall with fake wood) is degraded in some areas
2- Same problem with the fabric fibers (cotton) in close-up
3- There is also a problem with skin (like abs) which looks like “posterized”.
I think that 1 and 2 happen because thm2 “confuses” the very fine similar “lines” of the wood or the fabric (maybe it “believes” that there is “motion blur” there).
→ Please how is it possible to use thm1 ? Is there a way to download it somewhere and to put it in the right directory?
thm1 was perfect, the images were crystal-clear (for exactly the same scenes), it was really perfection.
But sadly, now that thm2 has been released, I cannot use Motion Deblur anymore, as it “ruins” my clips, quite a lot.
For me it’s nonsense.
thm1 was perfect, so why changing ?
If thm2 is good for the other users, if they don’t have or see these obvious problems, well, that is good for them…
The laptop used has Windows 11 and a Geforce GPU.
But anyway there was no problem at all with thm1. I just need thm1.
I asked various times to email support, in vain…
Hello and thanks again.
I cannot find any REPLY button anymore in that thread (beta testing).
I installed the beta but thm1 in it has the same problems as thm2, that I described there in the thread (no one answered).
Worse, today I installed the latest beta 3.2.4.1b and Themis V1 disappeared.
And there are the vertical/horizontal problems that I said.
How to be able to post in that thread, and to have someone paying attention ?
Thanks.
