V5.5 - USING 60FPS MAKES IT 59.94
To improve quality, before I apply enhancements, I convert fps of any input video to 60fps.
It worked fine before v5.5.0.
Now it converts the video to 59.94fps.
I tried the second time, that with 59,94fps, and I got 59.932fps.
I have to uninstall v5.5 and get back to v5.4 :((
What codec are you using for these conversions?
Can you send the logs to the support team for investigation? help@topazlabs.com
Could this be a general problem?
Issue is general indeed. Makes the software pretty much unusable for the time being for me. Please fix asap.
