V4.1.0 is it Proteus3 or Proteus4?
Under Model Updates, the release notes describe Proteus v4. After exporting a file the metadata show “Enhanced using prob-3”, which is the same as when exporting with Proteus v3.
My question is, which is wrong, metadata or release notes?
it’s good proteus v4. you just have to see the difference in quality on a preview… :slight_smile:
that is strange, because mines do show Proteus 4.
but mines have previous versions turned on in preferences, so I saw that v4 was selected when exporting.
Thank you for the screenshots.
I found the cause, obviously lack of knowledge on my side. Being not aware that different versions of a model can coexist, I restored a preset saved with the previous version of VAI for my tests and thus, Proteus 3 was used. Creating a new preset from scratch fixed the problem.
Now, I have enabled previous model versions, which seems to be disabled by default, to see in the GUI what model is used.
