V3.5.4 exporting trimmed clips with 'Reduce Jittery Motions' with Interlacing is causing 2 issues
V3.5.4 exporting trimmed clips with ‘Reduce Jittery Motions’ and Interlacing is causing 2 issues. But with Progressive it works fine.
It is causing:
  1. Several boxes blurred on fades from black.
  2. Total running time of the clip is wrong - the end is missing.
I am using the following settings for interlacing:
Resolution Control: 3840 x 2160 (4K)
Frame Rate: 23.976 FPS (1 x Deinterlaced)
Enhancment:
VideoType: Interlaced.
Field Order: Auto-Detect.
AI Model: Iris MQ 2X FPS.
Stabilisation:
Method: Full-Frame.
Strength: 50.
Reduce Jittery Motion: Active.
Number Of Passes: 2.
Thank you, we will be looking into this!
