I’m pretty sure it’s this, with frame interpolation on, 2x slomo, Chronos.
BTW, I did try the Edit > Apply Preset you suggested as a fix, this doesn’t seem to have any effect on anything. Nothing changes in the interface at all when I select this.
Is it at all possible to capture the preset being made with the settings shown and then it being altered by the app? I appreciate all you have shared so far, I just have not been able to replicate this behavior on my end.
I’m sorry but I tried to recreate it and I couldn’t either. One problem is that I don’t know what triggered the original issue. Here’s what happened the best I can remember, maybe this helps:
-Was using previous version (probably 3.2.2), presets worked as expected. I loaded my typical preset, but for the particular sequence, I decided to use some different settings, so I changed some. I’m pretty sure the ones in the video above are what I ended up exporting. I did NOT save over my preset with the new settings.
-After exporting, I closed the program as usual.
-The next day, when I launched the software, the prompt was there to update to 3.2.3, so I did.
-Once I relaunched, and loaded a sequence, and chose my preset as usual, it was these other new settings, the ones I had likely used for my last export, but not saved.
-Not only is the one preset altered, but now when I select my other preexisting ones, they have the altered settings as well. This has basically erased my custom presets.
-My best guess is that this is something that happened to my custom presets in the update, which is why I can’t recreate it now.
Hope that helps, thanks
Thank you We are working to recreate this issue and are working to clean up the preset process in general.
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
