My Nikon z9 files are having terrible color change when treated directly on Topaz or via Lightroom into Topaz… the outcome is coming with terrible colors (in many cases strong magenta color), and photos are not in condition to be used. With that I am not able to use Topaz…
Would you please review it and provide solution? Thanks
André
You can securely submit your image(s) to my Dropbox using the link below. Please be sure to send me a note to let me know you sent something. Dropbox File Request
Thanks for sending the file. It looks like there are two issues here.
Camera Vivid profile is causing the color shift
There is an issue in the metadata causing affecting the white balance.
To prevent the color shift, I would recommend against using Topaz Photo AI in stand alone mode. Please try the Photo > Edit in > Topaz Photo AI method from within Lightroom instead.
We added a fix for this color shift issue with the Z8 and Z9 HE* files in v2.0.2. Please update and use the Raw processing, the colors will stay consistent now!
Hi, thanks for the contact.
I installed the new update, and yes, the Magenta color issue was gone for this image in discussion, and few others that I tested (image SOOC from lightroom to Topaz, back to lightroom. I had to reset to get closer to the original image).
But now I see another issue, also appeared in other testing files (I will need to spend more time to see the consistency of the issue). please see same image from above with a zoom in the region with impact on the image.
This is the same image I shared with you via dropbox, maybe you could simulate same issue. I noticed that the more Sharpening in Topaz it is added the more “white” spots appears.
We have a fix for this in the release coming this Thursday, we found an issue where colors were shifted in color channels where it reaches the maximum value.
