Here is the workflow.
-Took a raw RW2, ran it through new PR SharpenAI, saved as TIF
-Took TIF into TS, cropped, AIC and Basic (only adjusted white/black points), saved as TIFF (since TS doesn’t have TIF)
Took that TIFF file into new PR Gigapixel, 4x and None, None, don’t change format.
Jpeg was ok, but Tif is very weird. Below is a screenshot of the file I brought into Gpxl in the upper left corner.
I ran it again in our Beta and received the same results. Also had a friend run it through Gpxl with the same results.
Recreated this. Very strange indeed. @topazjosh Take a look at this. Something in the metadata may be causing the new tif output logic to produce this psychedelic output. I’ll send you the file internally.
