Using topaz Mask AI with topaz backgrounds
I have used topaz mask AI to cut out the background on a portrait. I then want to use the textures from Topaz studio 2 to fill in the cut out background. How do I do that. what is the workflow.
thanks
Once you’ve returned your image to Studio, just add the texture of your choice and then in the layer stack drag the texture filter below the Mask AI (Output) layer.
