Sharpen AI v 2.0.5
When I pass a JPG picture from Windows Explorer using Open with… Topaz Sharpen AI.exe, program opens and the picture file is correctly loaded in Sharpen AI. But when I want to save the modified picture using the Save Image button, the dialog box “Save Image As” does not appear and the processed image overwrites the initial picture file. Is there a mean to avoid that ?
In addition, I observe that the menu File only shows commands: Accept, Cancel and Preferences…
I have changed to a product feature request for you as none of the current crop of Topaz Labs applications use the Open with command from the Win Explorer … this may be because most are used as a “plugin” from other applications and some are fitted with Batch processes.
Don’t forget to vote for it in the top LH corner.
