After initially just using Auto pilot on a sequence of images, I found that the ones with a low shutter speed had a neon yellow/green color in the resulting DNG image that is synchronized with Lightroom.
Steps to reproduce issue:
Low shutter speed Adobe RAW image added to PhotoAI for processing. Original image is ISO 100 f/11 at 1/5sec to capture waterfall moving around great blue heron at sunset.
Tried to resolve by refining the subject a bit and same result. Turned off sharpening with same result. Using Topaz DeNoise AI on its own does not generate the issue.
Synchronized image with Lightroom catalog.
Topaz Photo AI v1.4.2 on Mac
2023-07-23-22-02-58.tzlog (683.4 KB)
