FFMPEG for VEAI has limited filters and codecs due to the GPL license.
You can check the available filters and codecs with “ffmpeg -filters”, “ffmpeg -encoders”, etc.
" eq" was not available.
The only way to deal with this is to use a limited filter, export to ProRes etc and apply a color adjustment filter again, or use the pipe function to connect the two.
