Anyone knows if this could be an option for upscaling using TVAI?
It is a power cloud computing that has hourly fees using Lambda and you can select the GPU to be used.
Another option I found
I know of at least one user on these forums that was using a cloud service for TVAI. No idea what one, just that it was working.
If the cloud service offers Windows, macOS, or Linux as an option, and you’re allowed to install apps on it, then you can use it for processing with TVAI.
Note: Linux requires using the Beta version of TVAI plus being a bit more careful with dsitro, TVAI installation, and hardware configurations.
