PC, Windows 11 Pro, currently on the laptop with Photo AI 2.0.3
I’m not at home, so I can’t see if what I THINK was happening there on the desktop when using 2.0.2 actually was. So this may be operator error or computer inconsistency or cosmic rays!
AT HOME:
I start Photo AI. It just sits there waiting for an image.
I go to Lightroom and do normal processing. At some point I want to use Photo AI so I export the image to Photo AI - I BELIEVE the image went into the running instance of Photo AI. I could do normal upsizing, noise reduction and sharpening, whatever, then process the image. PHoto AI sent the image back to Lightroom and the image STAYED open in Photo AI. I could change the upsizing or sharpening or whatever and rerun the processing. Eventually, I’d go back to Lightroom and have multiple outputs from PHoto AI WITHOUT having to export the image over and over.
ON THE ROAD:
I’m traveling with a Windows 11 Pro laptop, and I just installed 2.0.3 (it had 2.0.2 and did the same thing).
I tried doing the same thing, but it LOOKS like I get a second instance of Photo AI every time I export an image, and it closes every time it processes the image.
Is there a preference or some other setting (something in Windows?) I’m missing that makes this work? I looked in the preferences, and the ONLY thing I could find that might be applicable was “Close images after saving”, which I have turned OFF so “Images will remain open after they are saved.”
Anybody had an idea what I’ve got set wrong?
