User Default settings for Topaz AI Remove Tool
It would be good to have a default speed / quality and a default brush size in the user settings.
This would speed up image processing when doing batches of similar files.
Thanks for the idea and suggestion about the default setting for Brushes while using Topaz Photo AI!
Make sure that you do not forget to vote for your idea :slight_smile:
