Used Topaz trial - liked those results better
Any clue on how to retrieve the work I’d previously done in Topaz Trial?
Hello,
Unfortunately videos processed in the trial mode would need to be re-exported with the watermark not applied. The app functions identically other than the watermark, so we should be able to export the same result. With the app logs, I can help find the settings that would match the output from the trial mode:
Could you send us an email at help@topazlabs.com with the full log files from the app?
To gather logs, please select Help > Logging and make sure that there is a check mark next to File Logging. Next, recreate the issue and then return to the Help menu and select > Get Logs for Support and attach the “logsForSupport” file to your reply.
