The bug / behavior you have encountered
Upscaling using the interlaced models Dione DV, TV or Dehalo produces a output video with audio slightly out of sync -
Your system profile
Mac Mini M1 / 16 GB with Mac OS 15.1.1
Topaz Video AI 5.5 -
Your log files (Help > Logging > Get Logs for Support)
FFmpeg command:
ffmpeg “-hide_banner” “-t” “2462.936” “-ss” “61.624” “-i” “/Volumes/video/DVD Rips/Babylon 5/Babylon 5 - S01E01 - Ragesh 3.mkv” “-sws_flags” “spline+accurate_rnd+full_chroma_int” “-filter_complex” “bwdif=mode=0:parity=-1:deint=0,tvai_up=model=dtvs-2:scale=0:w=1350:h=1080:device=0:vram=0.5:instances=0,scale=w=1350:h=1080:flags=lanczos:threads=0” “-c:v” “hevc_videotoolbox” “-profile:v” “main10” “-tag:v” “hvc1” “-pix_fmt” “p010le” “-allow_sw” “1” “-g” “30” “-b:v” “0” “-q:v” “60” “-map” “0:a?” “-map_metadata:s:a:0” “0:s:a:0” “-c:a” “copy” “-map_metadata” “0” “-map_metadata:s:v” “0:s:v” “-map” “0:s?” “-c:s” “copy” “-movflags” “frag_keyframe+empty_moov+delay_moov+use_metadata_tags+write_colr” “-bf” “0” “-metadata” “videoai=Deinterlaced and enhanced using dtvs-2. Changed resolution to 1350x1080” “/Volumes/EXTMEDIA/TOPAZ_UPSCALED/Babylon 5 - S01E01 - Ragesh 3_863532075.mkv” -
Any screenshots as necessary
I can provide video examples on request.
