Problems with upscaling:
PhotoAi does just a partial job leaving an unsuable file (jpg ->jpg conversion). Does not happen to all files, but at the moment for about 50%; on both patch jobs and single prosessing.
Workflow AcdSee PhotoStudio Ultimate 2024 → Topaz PhotoAi 2.2.0
Usual upscaling 2x, but the amount has no effect.
The jpg’s come from Capture1 2022-version.
Problem has occurred both on “dropping the files to PhotoAi” and selecting “edit->PhotoAi” in AcdSee.
Sometimes renaming the file helps, but not always.
Seem to need some fix in the PhotoAi.
Jouko Lehto
