Upscale x1 issue
I’m on v3.0.4. When I use Upscale 1x, the output file size is significantly reduced to nearly half the original jpg file size. I have increased the slider to 100% so would expect the file size to be retained but it’s not. Please advise.
Steps to reproduce issue:
  1. Step 1 - choose Upscale
  2. Step 2 - set scale to 1x
  3. Step 3 - set output file type to jpeg, quality slider to 100%
  4. Step 4 - Press Save
  5. Step 5 - note on next screen that it says file goes from (original) 15.8 Mb to ~14 something Mb
  6. Step 6 - check file saved and it says file size is 9Mb
Topaz Photo AI [v3.0.4] on [Mac]
I was not able to replicate this on my machine but would like more information as to the workflow you are using while this issue occurs.
Would you please take a screen recording of this behavior so I can see exactly what is happening?
Loom is a great free application for this: Loom | Free Screen & Video Recording
