Upscale to PRO RES issues
I have been upscaling to PRO RES, LT and or STD, and it spends 12 hours on a RTX 4060 ti, then has a nice looking 160GB file. Then I try to preview it, but no player can open it. MKVToolNix cannot open it to re-mix it. Handbrake cannot open it. This is a powerful video editing machine with nothing on it except topaz and DaVinci for large programs.
What is the purpose of keeping Topaz Video AI or Topaz Video?
Is their programming is not being supported buy their programmers?
The process to have a good upscale is to use the best filters possible, upscale to uncompressed, then compress it after in HandBrake or DaVinci. But nothing can open or access the file created by Topaz Video AI. Here is the starting video clip specs, the source video that plays by the way perfectly in every player including thru AppleTV 4K thru Plex player client on my Sony 65" Bravia.
I’m now trying alternate products with UniFab, but would much rather stick with more proven AUI and smoothing. I am frustrated, and have paid for the full licenses going back to about 2020. I feel I have been abandoned and rejected by their senior managers, CIO, CFO and CEO.
General
Complete name : D:\Movies Basement\title folder was here)\title.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/dby1/iso2/avc1/mp41)
File size : 5.93 GiB
Duration : 1 h 39 min
Overall bit rate mode : Variable
Overall bit rate : 7 508 kb/s
Frame rate : 23.976 FPS
Collection : Title of movie was here
Track name : Title of movie was here
Genre : ;;;
Description : really cheesy summary of story was here, written by gen X’rs that cant write
Recorded date : 2026
Writing application : Lavf62.3.100
Cover : Yes
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 6 840 kb/s
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.186
Stream size : 4.77 GiB (91%)
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Codec configuration box : avcC
Audio
Format : E-AC-3
Format/Info : Enhanced AC-3
Commercial name : Dolby Digital Plus
Codec ID : ec-3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 457 MiB (9%)
Title : English
Language : English
Service kind : Complete Main
Default : Yes
Alternate group : 1
Dialog Normalization : -24 dB
compr : -0.28 dB
dmixmod : Lo/Ro
ltrtcmixlev : -3.0 dB
ltrtsurmixlev : -3.0 dB
lorocmixlev : -3.0 dB
lorosurmixlev : -3.0 dB
dialnorm_Average : -24 dB
dialnorm_Minimum : -24 dB
dialnorm_Maximum : -24 dB
Text
Format : Timed Text
Muxing mode : sbtl
Codec ID : tx3g
Duration : 1 h 32 min
Bit rate mode : Variable
Bit rate : 70 b/s
Frame rate : 0.589 FPS
Stream size : 47.4 KiB (0%)
Title : English [CC]
Language : English
Default : Yes
Forced : No
Alternate group : 3
Count of events : 1636
The older app Video AI was discontinued last year and replaced by the newer app Topaz Video. Users do not have to keep the older app if they do not want to do so. Removing it will save hard drive space, but some users do prefer to keep it for use in some workflows.
We would need the logs to review the processing that occurred for the devs to take a look at. Possible that some of the metadata tags, or audio tracks, are hitting an issue with the other players and apps.
Can you grab the logs and send to the support team at help@topazlabs.com for review?
One advantage of keeping the old Video AI installed is that because it’s no longer being updated, its results are consistently predictable. Some of us have been seeing new builds of Video introduce new bugs that break older models like Rhea and Proteus, and it’s useful to have a backup app for those.
Also, if you happen to have more than one GPU, you can assign each app to a different GPU. I’ve done simultaneous runs using Starlight on Video and Rhea or Proteus on Video AI with no conflicts and no noticeable speed impacts on either.
And lastly, the old Video AI license allows two seats of that app, compared to the current Video subscription that allows one.
Holy moly you replied!
I’ll try to find the logs of when the pro res was used.
I hope topaz always stays supported. I’ve been deep in 8mm film transfers and other videos since 2002 when I got my first 2.4gz machine called a”Shuttle” at the time a super fast machine. And topaz video AI is great.
