Upscale Restart Process
I am bulk upscaling videos to 4k with the Rhea model. On average, I see that it takes around two minutes to complete the process. However, the app will consistently hit a video processing in the mix that takes over an hour and I can see in the processing time remaining view. Is there a setting I can enable that tells the app that if the processing time is greater than x amount of minutes that it should restart the process until the estimated time is reduced to less than 5 minutes or so?
This would greatly improve my workflow as I set the app to run overnight while processing greater than 20 videos. I see it processing when it starts and completes the first couple of videos within two minutes then open the app the next morning and see it stuck on one video with greater than 50 minutes processing.
This probably should be retitled, as ‘Batch Processing Auto Bypass Longer Processing Time Jobs To Smaller to Larger’ or something more clear because, Upscale Restart Process just makes it seem like restarting failed/cancelled queued jobs.
Maybe this one, “Process Queued Batch Jobs in Estimated Job Time Size Order”
