Upgraded to Sonoma 14.5 and now TopazAI 2.4.2 is unusable
Steps to reproduce issue:
  1. Step 1
  2. Step 2
  3. Step 3
I use it as a standalone. I am guessing I will not be the only one.
Hope you can help.
Thank you… I’m waiting for more data before updating my Mac.
Did you try any of the older or newer versions?
Has anyone else updated a Mac, and what Topaz software worked or didn’t?
…Sam
Please follow the instructions below to fix this issue:
Topaz Photo AI Freezes on Importing Image (Mac)
Let me know if it’s working after doing this and I’ll keep an eye out for your reply.
Many thanks. Your instructions worked perfectly!
