Unknown issue! at least i do not know how to fix it and what happened to my video ai
1.i do nothing but it keeps to abort the progress
2.AIDA64 Upload Report.zip (474.7 KB)
3.Log File is here
logsForSupport.zip (269.5 KB)
4. this is the only one screenshot i could get!
I am having this exact same issue. In event viewer I see “resource exhaustion” and looking at logs TopazAI is consuming over 50gb combined system memory and virtual memory when it crashes.
I used to process the same files (and have now tried 3 different videos to be sure) and I crash 100% of the time after a few hours of processing.
Please fix this Topaz team. This is the 4th breaking issue I’ve had this year, I’d like to get a license extension if possible as I have lost weeks upon weeks of processing time due to bugs in Topaz this year.
i got those red cross errors too often especially when I run a game at the same time either the game or video a. i. crashed some time after. the issue disappeared when i set a temperature limit of 80 °C for the cpu in the bios. :eyes:
I have been processing successfully for a year without error (except with previous faulty Topaz versions), and the issue popped up after a Topaz update so I am inclined to think it is a problem with the program. Especially given the Windows Event Logs indicating resource exhaustion… Topaz has never tried to use 50+ GB of RAM in the past (32gb physical +18gb virtual/swap)
Also the system in question is entirely unused outside of processing in Topaz.
i keep looking for the solution.
Does anyone find out the solution?
You can set some limits in the Preferences>Processing to limit max memory % and max processes that will help keep your GPU from getting overwhelmed. Also stacking more than two AI filters on one clip can cause the memory error messages.
