Unacceptable color shift
Drastic color shift on all images. The image loads up looking correct (unlike Gigapixel which already shifts the color when loading in the original file…) but the output file is dramatically shifted in color and tone. No matter what settings. All my creative work undone, and impossible to recover in post by taking back into photoshop.
Have attached screenshots showing both autopilot settings, and my own settings to get the image closer to what i wanted… both unusable.
  1. Step 1 - open an image
  2. Step 2 - set scale to anything other than x1
  3. Step 3 - no settings help to correct the color shift.
Topaz Photo AI [v1.x.x] on [Mac]
wow, for some reason that first image looks like a good match in the web preview attached - but it doesnt look like that uncompressed on my desktop. Please check the actual file i uploaded so you can see it properly. The upscale has made the sky light all muddy-yellow, when in the original its actually a turquisey blue. So a total color shift and tonal change.
Seem like you might have a colour management problem somewhere in the workflow. Are colour profiles being preserved throughout the file chain (input to output)?
you can clearly see the color is shifting when i apply the upscale model, within the software.
while the upscale is applying it looks perfect, then as soon as its finished applying the color shifts. it seems to be issue with the software/model color accuracy?
there doesnt appear to be any settings within the software to set or apply different color management.
of you have any advice of things to try, or ive misunderstood let me know
On the screenshots you’ve posted the output previews look almost identical in colour (the second shot might be very slightly darker).
For colour management, I was referring to the input and output files embedded colour profiles. Are they the same? Or has the colour profile changed? Colour space conversions could result in tonal shifts.
thanks. yes, if the first image looked like that in real life, i would be very happy, but its actually nowhere near that close irl. i dont know if the upload converted the file somehow, but its nowhere near that good as i look at it on my desktop. The sky has a warm golden hue, instead of a cool turquoise hue - which is a dramatic shift. I could email the actual screengrag if you want to see what im talking about.
These are fine art works adn i cant have the whole things tonal quality altered like this - also to lose hours of color correction isnt acceptable for a workflow. And like i said - the color/brightness is not recoverable by trying to recorrect in post after upscaling. the information is gone. Also this is just one example, of a collection of 20 artworks in this series.
re color profiles, my images have srgb embedded, i open them in the app and it shifts the color after applying the model. i dont see how/where color space could be getting lost from my side of things? i also see no controls over color space in Photo AI app at all. I havent even saved them out of the app yet and its already changed the color.
sorry just frustrated. Gigapixel does a near-perfect job of matching colors within the app, BUT it opens some files (particularly with blues/green colors) with a shift already present - which definitely seems like a color space problem with the app not reading/recognizing my embedded profiles - and no place to set this manually in the app?
So even though in Gigapixel the original preview perfectly matches the upscaled preview in the app - the original preview doesnt actually match the artwork file. Its super frustrating!
And now Photo AI opens the file with the correct colors in the original preview BUT has a terrible shift after upscaling.
I don’t have any experience with mac colour management to know whether the app itself is the source of all the problems. I’ve not seen these issues on PC, especially with sRGB profiled images.
Previously seen some issues with wider gamut images, and often the source of the problems is viewing input or output files on non-colour managed viewers. As far as I know colour management is handled at a system level on mac.
For Denoise, the tif file after processing shows all sliders for Tone adjustment are at neutral position. For Photo AI, Tone adjustment sliders position are similar to the Raw file. If the Tone adjustment sliders of the tif file are set back to neutral position, it will match the adjusted Raw file. Why Topaz Photo AI has that problem, whereas Denoise is OK.
Hi @lucei, can you upload a couple copies of both your pre-processed and post-processed images for us to compare?
Dropbox File Request
I just tried with Version 1.3.0. the problem seems to go away. Previously, after processing (launched from Lightroom), the adjusted image in tif file seems to show the same tone and curve adjustment of the raw file, which will cause shift in the tone, the tif file should show both tone and curve adjustment in the unadjusted value.
I have uploaded the files before and after Photo AI. If you view both files with Window Photo Viewer you don’t see the issue. If you import the 2 files into lightroom, you will see the difference. The Tone and Curve adjustments made on the Raw file seems to be copied back into the tif file after processing causing the shift in the tone. The tif file before Photo AI has all Tone and Curve adjustments in the neutral position, but the tif file after Photo AI has all Tone and Curve adjustments of that of the Raw file causing the shift. This issue is not seen with Denoise or Sharpening. Issue seems not present if I don’t process the photos launch from Lightroom.
Thanks for sending the files. Which Lightroom Classic plugin are you using?
File > Plug-in Extras > Process with Topaz Photo AI
OR
Photo > Edit in > Topaz Photo AI
File > Plug-in Extras > Process with Topaz Photo AI will copy the adjustments from the original file to the output file.
Photo > Edit in > Topaz Photo AI will save the adjustments directly to the TIF file and not apply the settings a second time.
