Window pops up. IPC MEMORY IN USE, IMAGE SIZE TO BIG FOR THE SYSTEM. You sent me a link that doesn’t work. .
Please post the link here …
To correct that error:
- Make sure you are not using any host such as Photoshop, if you are exit.
- Type %temp% in the explorer address line, press enter, and then delete any folder that starts with “boost_interprocess_”
Im having the same issue that is only occurs with clarity. i’m the system admin and it won’t let me delete that file.
Make sure you have exited photoshop. If you have and can’t delete, reboot and delete before you start any apps.
