- The bug / behavior you have encountered
- Your system profile
- Your log files (Help > Logging > Get Logs for Support)
- Any screenshots as necessary
- UI Crashes just swiping back and forth to look at minimum render.
- nVdia RTX 3080, Intel Core i7-9800X, 64GB Ram [The system profile export is in sysinfo.zip]
- Logs in .zip
- It crashes to the desktop, nothing to see. I tried it on an AMD Threadripper 1950X 16 core, 48GB, AMD RX 7900 XTX, but it just crashes after a few hours. In general, the software is not stable on the AMD GPU. We can look at that later, I want to use my nVidia system instead.
sysinfo.zip (160.4 KB)
logsForSupport.zip (9.9 MB)
