Hello friends.
Here you can download Radeon 2020 drivers tweaked by me,
focused on the speed of computing.
These are something similar to Nvidia Studio Drivers.
All games etc will work (probably even faster, with more FPS), but you can check if your Topaz works go faster now.
When I would have some free time, I will do the same for Nvidia and for latest Radeon drivers.
BR & have fun
Thomas M. Pirowski
How to install: 1. download. 2. unpack 3. start “setup.exe”.
You may be informed, that these drivers are older, than your actual drivers. Install anyway.
Improving the overall efficiency of VRAM usage, by disabling DMA copying, enabling block write, come corrections to power gating and tweak, that blocks idle.
Some minor changes, good for speed & stability like blocking analytics, increasing TDR delay, correcting thermal throttling behaviour.
As I know all these things may sound difficult, I have prepared a registry tweak file. You can download it and just start. All corrections will be done automatically. You need to restart your system, so new setup will be loaded by AMD driver.
Of course, tweak will help also while using other render systems and even - games (check your FPS before & after
download, 2. unpack. 3. click.
Windows will tell you that blah blah blah modifying of registry may be dangerous etc. Click “install anyway”. 4. restart Windows. Remember, that this tweak is for RADEON only with my driver, or at least standard driver from 2020).
I can not install it because the setup.exe tells me that it can not find any AMD hardware. I know this is an old issue with this type of installer and could normally be avoided by installing the driver via the device manager of Windows, but then it says the best matching driver is already installed.
