Thanks for your vidéo, I’m going to work on it to create a good preset
Here is the link to your video, I worked on a new preset for the HI8 1080 on Proteus 4
Have you receveid ?
not bad! but I find that in all cases, above HD, there is no use because there is not enough basic detail so there is a lot of loss of detail compared to original video and quite distorted details. Thanks for your test anyway
for the color how did you proceed? I have the impression that it’s in HDR, right?
and deinterlacing? I notice that there are still traces of interlacing on the fast movements, everything is done with vai?
Thank you for your feedback. but given your answer I think that was not what you are looking for as a result I have the impression. I worked on tveai first and for color on resolve, And it’s in SDR not HDR.
yes I’m not looking to upscale in fhd, just in hd, because for me there is too much loss of detail and it looks less natural, but I admit that your settings are really good all the same for someone who is looking of the fhd. and I plan to apply a final grain in the sequences because it hides the plastic effect or the few artifacts that may remain.
I am looking for a preset for 1280x720 from bad quality videos for example 688x470 sources. If you can help me with that I can send you a video for example?
It hard to usee the settings in json. Can you add them as normal text?
What are the instructions to using the presets you should include them below lol. how do i add it
Just found out myself after having some trouble. You have to access the programdata folder which was hidden. What I did was open file explorer, click view tab, hover over scroll, and then check hidden items. The programdata folder is hidden so you unhide it this way. You then go to programdata, Topaz folder, Video AI, then presets. The presets downloaded on this site you then copy paste the files into that preset folder and then should be good. Close program first if open but should show up after.
Hi, I know this is a year late but here is the answer for anyone looking:
- Go to Applications
- Find “Topaz Video AI”, right click and press “Show Package Contents”
- You will the presets folder under /Contents/Resources/presets
- Add your presets to this folder
Im pretty new to this. Im also not really a computer guy. How do I add these settings to Topaz via the commands?
does it usefull on 5.xx version?
I just found this and I THANK YOU! I hope they will give me a base to start from - I have only used sharpen or denoise.
What about for Win 11?
