TVAI ver. 5.0.4 audio bug
Since your previous update 5.0.2 the soundtrack seems to be de-synchronized when using audio “copy” mode in the [preview & export settings] menu. If I want a soundtrack well synchronized with video track, I have to use the “convert” audio mode in the [preview & export settings] menu.
What AI models are you applying to the videos when running these exports?
I dont’t use model’s library. I only use my own preset named “VIEUX DVD”
I just tried to run a new test with the same preset. So, when I watch the final result, the sound appears only after 1’ 50’’
logsForSupport.zip (15.1 MB)
regards,
Philippe GIRAUD
