TVAI 6.0.1 - Changing audio in preset reset manual proteus v3 to auto
Windows 11
  • Select some preset from the list of the presets.
  • Click on Codec settings tab
  • Change Audio mode from Copy to None
  • Back to Adjustment tab
    Now my Manual setting for Proteus v3 model resets to a default Auto mode.
This is a UI bug, the manual parameters should still be applied when you export the file. Our team is aware and working on resolving this.
